A Kd Tree Class which implements functions related to point to point distance.
More...
#include <KdTree.h>
KdCell * | buildSubTree (unsigned first, unsigned last, KdCell *father, unsigned &nbBuildCell, GenericProgressCallback *progressCb=nullptr) |
| Builds a sub tree. More...
void | deleteSubTree (KdCell *cell) |
| Deletes a sub tree.
void | updateInsideBoundingBox (KdCell *cell) |
| Computes a cell inside bounding box using the sons ones. The sons bounding boxes have to be up to date considering the points they contain.
void | updateOutsideBoundingBox (KdCell *cell) |
| Computes a cell outside bounding box using the father one and the cutting plane.
ScalarType | pointToCellSquareDistance (const PointCoordinateType *queryPoint, KdCell *cell) |
| Computes the distance between a point and a cell inside bounding box. More...
ScalarType | InsidePointToCellDistance (const PointCoordinateType *queryPoint, KdCell *cell) |
| Computes the distance between a point and the outside bounding box of the cell in which it lies. More...
void | pointToCellDistances (const PointCoordinateType *queryPoint, KdCell *cell, ScalarType &min, ScalarType &max) |
| Computes the distances (min & max) between a point and a cell inside bounding box. More...
int | checkNearerPointInSubTree (const PointCoordinateType *queryPoint, ScalarType &maxSqrDist, KdCell *cell) |
| Checks if there is a point in KdCell that is less than minDist-apart from the query point, starting from cell cell. More...
bool | checkDistantPointInSubTree (const PointCoordinateType *queryPoint, ScalarType &maxSqrDist, KdCell *cell) |
void | distanceScanTree (const PointCoordinateType *queryPoint, ScalarType distance, ScalarType tolerance, KdCell *cell, std::vector< unsigned > &localArray) |
| Recursive function which store every point lying to a given distance from the query point. More...
KdCell * | m_root |
| Tree root.
std::vector< unsigned > | m_indexes |
| Point indexes.
GenericIndexedCloud * | m_associatedCloud |
| Associated cloud.
unsigned | m_cellCount |
| Number of cells.
◆ buildFromCloud()
Builds the KD-tree.
- Parameters
cloud | the point cloud from which to buil the KDtree |
progressCb | the client method can get some notification of the process progress through this callback mechanism (see GenericProgressCallback) |
- Returns
- success
◆ buildSubTree()
Builds a sub tree.
- Parameters
first | first index |
last | last index |
father | father cell |
nbBuildCell | nbBuildCell |
- Returns
- sub tree (cell)
◆ checkDistantPointInSubTree()
bool KDTree::checkDistantPointInSubTree |
const PointCoordinateType * |
queryPoint, |
ScalarType & |
maxSqrDist, |
KdCell * |
cell |
protected |
Optimiszed version of CheckNearerPointInSubTree since we don't want to find the nearest point, but only check if there is a point that is close enough
- Parameters
queryPoint | the query Point coordinates |
maxSqrDist | square of the maximal distance from querypoint |
cell | kdtree-cell from which to start the research |
- Returns
- true if there is a point in the subtree starting at cell that is close enough from the query point
◆ checkNearerPointInSubTree()
int KDTree::checkNearerPointInSubTree |
queryPoint, |
ScalarType & |
maxSqrDist, |
KdCell * |
cell |
protected |
- Parameters
- Returns
- -1 if there is no nearer point from querypoint. The nearest point index found in cell if there is one that is at most maxdist apart from querypoint
◆ distanceScanTree()
void KDTree::distanceScanTree |
queryPoint, |
ScalarType |
distance, |
ScalarType |
tolerance, |
KdCell * |
cell, |
std::vector< unsigned > & |
localArray |
protected |
- Parameters
| queryPoint | the query point coordinates |
| distance | the wished distance from the query point |
| tolerance | tolerance for resulting points : p is in resulting array if ||p-queryPoint||<=tolerance |
| cell | current cell to explore (used for recursion) |
[out] | localArray | output of the algorithm. Resulting points m_indexes in associatedCloud are stored in this array |
◆ findNearestNeighbour()
bool KDTree::findNearestNeighbour |
queryPoint, |
unsigned & |
nearestPointIndex, |
ScalarType |
maxDist |
Nearest point search.
- Parameters
queryPoint | coordinates of the query point from which we want the nearest point in the tree |
nearestPointIndex | [out] index of the point that lies the nearest from query Point. Corresponding coordinates can be retrieved using getAssociatedCloud()->getPoint(nearestPointIndex) |
maxDist | distance above which the function doesn't consider points |
- Returns
- true if it finds a point p such that ||p-queryPoint||<=maxDist. False otherwise
◆ findPointBelowDistance()
bool KDTree::findPointBelowDistance |
queryPoint, |
ScalarType |
maxDist |
Optimized version of nearest point search method.
Only checks if there is a point p into the tree such that ||p-queryPoint||<=maxDist (see FindNearestNeighbour())
◆ findPointsLyingToDistance()
unsigned KDTree::findPointsLyingToDistance |
queryPoint, |
ScalarType |
distance, |
ScalarType |
tolerance, |
points |
Searches for the points that lie to a given distance (up to a tolerance) from a query point.
- Parameters
queryPoint | query point coordinates |
distance | distance wished between the query point and resulting points |
tolerance | error allowed by the function : each resulting point p is such that distance-tolerance<=||p-queryPoint||<=distance+tolerance |
points | [out] array of point m_indexes. Each point stored in this array lie to distance (up to tolerance) from queryPoint |
- Returns
- the number of matching points
◆ getAssociatedCloud()
Gets the point cloud from which the tree has been build.
- Returns
- associated cloud
◆ InsidePointToCellDistance()
ScalarType KDTree::InsidePointToCellDistance |
queryPoint, |
KdCell * |
cell |
protected |
- Parameters
cell | the cell containting the query point |
- Returns
- the distance between the point and the cell border. If this value is negative, it means that the cell has no border.
◆ pointToCellDistances()
void KDTree::pointToCellDistances |
queryPoint, |
KdCell * |
cell, |
ScalarType & |
min, |
ScalarType & |
max |
protected |
- Parameters
cell | the cell from which we want to compute the distance |
min | [out] the minimal distance between the query point and the inside bounding box of cell |
max | [out] the maximal distance between the query point and the inside bounding box of cell |
◆ pointToCellSquareDistance()
ScalarType KDTree::pointToCellSquareDistance |
queryPoint, |
KdCell * |
cell |
protected |
- Parameters
queryPoint | queryPoint coordinates |
- Returns
- 0 if the point is inside the cell, the suare of the distance between the two elements if the point is outside
