CCCoreLib 31 May 2022
CloudCompare Core algorithms
Mesh sampling algorithms. More...
#include <MeshSamplingTools.h>
Classes | |
struct | EdgeConnectivityStats |
Statistics on the edges connectivty of a mesh. More... | |
Public Types | |
enum | VertexFlags { VERTEX_NORMAL = 0 , VERTEX_BORDER = 1 , VERTEX_NON_MANIFOLD = 2 } |
Flags used by the MeshSamplingTools::flagMeshVerticesByType method. More... | |
static double | computeMeshArea (GenericMesh *mesh) |
Computes the mesh area. More... | |
static double | computeMeshVolume (GenericMesh *mesh) |
Computes the mesh volume. More... | |
static bool | computeMeshEdgesConnectivity (GenericIndexedMesh *mesh, EdgeConnectivityStats &stats) |
Computes some statistics on the edges connectivty of a mesh. More... | |
static bool | flagMeshVerticesByType (GenericIndexedMesh *mesh, ScalarField *flags, EdgeConnectivityStats *stats=nullptr) |
Flags the vertices of a mesh depending on their type. More... | |
static PointCloud * | samplePointsOnMesh (GenericMesh *mesh, double samplingDensity, GenericProgressCallback *progressCb=nullptr, std::vector< unsigned > *triIndices=nullptr) |
Samples points on a mesh. More... | |
static PointCloud * | samplePointsOnMesh (GenericMesh *mesh, unsigned numberOfPoints, GenericProgressCallback *progressCb=nullptr, std::vector< unsigned > *triIndices=nullptr) |
Protected Types | |
using | EdgeUsageMap = std::map< unsigned long long, unsigned > |
Map used to count the number of triangles using each edge. More... | |
Static Protected Member Functions | |
static PointCloud * | samplePointsOnMesh (GenericMesh *mesh, double samplingDensity, unsigned theoreticNumberOfPoints, GenericProgressCallback *progressCb=nullptr, std::vector< unsigned > *triIndices=nullptr) |
Samples points on a mesh - internal method. More... | |
static unsigned long long | ComputeEdgeKey (unsigned i1, unsigned i2) |
Computes the unique key corresponding to an edge. | |
static void | DecodeEdgeKey (unsigned long long key, unsigned &i1, unsigned &i2) |
Computes the edge vertex indexes from its unique key. | |
static bool | buildMeshEdgeUsageMap (GenericIndexedMesh *mesh, EdgeUsageMap &edgeMap) |
Creates a map to count the number of triangles using each edge. | |
protected |
Edges are represented by two 32 bits indexes merged as a 64 integer
Enumerator | |
VERTEX_NORMAL | Normal vertex |
VERTEX_BORDER | Vertex on a border/hole |
VERTEX_NON_MANIFOLD | Vertex on a non-manifold edge |
static |
mesh | triangular mesh |
static |
This methods counts the number of edges shared by 1, 2 or more faces. One or more edges used only by 1 face each indicates the presence of at least one hole. Edges used by more than two faces are non-manifold.
[in] | mesh | triangular mesh |
[out] | stats | output statistics |
static |
mesh | triangular mesh (closed!) |
static |
See MeshSamplingTools::VertexFlags.
[in] | flags | already allocated scalar field to store the per-vertex flags |
[out] | stats | output statistics (optional) |
static |
The points are sampled on each triangle randomly, by generating two numbers between 0 and 1 (a and b). If a+b > 1, then a = 1-a and b = 1-b. Let ABC be the triangle, then the new point P will be as AP = a.AB+b.AC (AP,AB and AC are vectors here). The number of points sampled on each triangle depends on the triangle's area. Let s be this area, and µ the sampling density, then N = s*µ is the theoretic (floating) number of points to sample. The floating part of N (let's call it Nf, and let Ni be the integer part) is handled by generating another random number between 0 and 1. If this number is less than Nf, then Ni = Ni+1. The number of points sampled on the triangle will simply be Ni.
mesh | the mesh to be sampled | |
samplingDensity | the sampling surface density | |
progressCb | the client application can get some notification of the process progress through this callback mechanism (see GenericProgressCallback) | |
[out] | triIndices | triangle index for each samples point (output only - optional) |
staticprotected |
See public methods descriptions
samplingDensity | the sampling surfacical density | |
theoreticNumberOfPoints | the approximated number of points that will be sampled | |
static |
See the other version of this method. Instead of specifying a density, it is possible here to specify the total number of points to sample (approximative).
numberOfPoints | the desired number of points on the whole mesh | |
