CCCoreLib 31 May 2022
CloudCompare Core algorithms
Public Member Functions | Public Attributes | List of all members
CCCoreLib::SquareMatrixTpl< Scalar > Class Template Reference
Square matrix. More...
#include <SquareMatrix.h>
 SquareMatrixTpl ()
 Default constructor. More...
 SquareMatrixTpl (unsigned size)
 Constructor with a given size. More...
 SquareMatrixTpl (const SquareMatrixTpl< double > &mat)
 Constructor from another double matrix. More...
 SquareMatrixTpl (const SquareMatrixTpl< float > &mat)
 Constructor from another float matrix. More...
 SquareMatrixTpl (const float M16f[], bool rotationOnly=false)
 "From OpenGl" constructor (float version) More...
 SquareMatrixTpl (const double M16d[], bool rotationOnly=false)
 "From OpenGl" constructor (double version) More...
virtual ~SquareMatrixTpl ()
 Default destructor.
unsigned size () const
 Returns matrix size.
bool isValid () const
 Returns matrix validity. More...
void invalidate ()
 Invalidates matrix. More...
Scalar * row (unsigned index)
 Returns pointer to matrix row.
void setValue (unsigned row, unsigned column, Scalar value)
 Sets a particular matrix value.
Scalar getValue (unsigned row, unsigned column) const
 Returns a particular matrix value.
SquareMatrixTploperator= (const SquareMatrixTpl &B)
 Matrix copy operator.
SquareMatrixTpl operator+ (const SquareMatrixTpl &B) const
 Addition.
const SquareMatrixTploperator+= (const SquareMatrixTpl &B)
 In-place addition.
SquareMatrixTpl operator- (const SquareMatrixTpl &B) const
 Subtraction.
const SquareMatrixTploperator-= (const SquareMatrixTpl &B)
 In-place subtraction.
SquareMatrixTpl operator* (const SquareMatrixTpl &B) const
 Multiplication (M = A*B)
Vector3Tpl< Scalar > operator* (const CCVector3f &V) const
 Multiplication by a vector.
CCVector3d operator* (const CCVector3d &V) const
const SquareMatrixTploperator*= (const SquareMatrixTpl &B)
 In-place multiplication.
void apply (const float vec[], float result[]) const
 Multiplication by a float vector, outputs a float vector. More...
void apply (const float vec[], double result[]) const
 Multiplication by a float vector, outputs a double vector. More...
void apply (const double vec[], double result[]) const
 Multiplication by a double vector. More...
void transpose ()
 In-place transpose.
SquareMatrixTpl transposed () const
 Returns the transposed version of this matrix.
void clear ()
 Sets all elements to 0.
SquareMatrixTpl inv () const
 Returns inverse (Gauss)
void print (FILE *fp=nullptr) const
 Prints out matrix to console or file. More...
void toIdentity ()
 Sets matrix to identity.
void scale (Scalar coef)
 Scales matrix (all elements are multiplied by the same coef.)
Scalar trace () const
 Returns trace.
double computeDet () const
 Returns determinant.
void initFromQuaternion (const float q[])
 Creates a rotation matrix from a quaternion (float version) More...
void initFromQuaternion (const double q[])
 Creates a rotation matrix from a quaternion (double version) More...
bool toQuaternion (double q[])
 Converts rotation matrix to quaternion. More...
Scalar deltaDeterminant (unsigned column, Scalar *Vec) const
 Returns Delta-determinant (see Kramer formula)
void toGlMatrix (float M16f[]) const
 Converts a 3*3 or 4*4 matrix to an OpenGL-style float matrix (float[16])
void toGlMatrix (double M16d[]) const
 Converts a 3*3 or 4*4 matrix to an OpenGL-style double matrix (double[16])
bool svd (SquareMatrixTpl &S, SquareMatrixTpl &U, SquareMatrixTpl &V) const
 SVD decomposition (inspired from https://github.com/dmalhotra/pvfmm/blob/develop/include/mat_utils.txx)
Public Attributes
Scalar ** m_values = nullptr
 The matrix rows. More...
Detailed Description
template<typename Scalar>
class CCCoreLib::SquareMatrixTpl< Scalar >
Square matrix.
Row-major ordered matrix (i.e. elements are accessed with 'values[row][column]')
◆ SquareMatrixTpl() [1/6]
template<typename Scalar >
CCCoreLib::SquareMatrixTpl< Scalar >::SquareMatrixTpl ( )
inline
Warning: invalid matrix.
◆ SquareMatrixTpl() [2/6]
CCCoreLib::SquareMatrixTpl< Scalar >::SquareMatrixTpl ( unsigned  size)
inline
Parameters
sizethe (square) matrix dimension
◆ SquareMatrixTpl() [3/6]
CCCoreLib::SquareMatrixTpl< Scalar >::SquareMatrixTpl ( const SquareMatrixTpl< double > &  mat)
inline
Parameters
matmatrix
◆ SquareMatrixTpl() [4/6]
CCCoreLib::SquareMatrixTpl< Scalar >::SquareMatrixTpl ( const SquareMatrixTpl< float > &  mat)
inline
Parameters
matmatrix
◆ SquareMatrixTpl() [5/6]
CCCoreLib::SquareMatrixTpl< Scalar >::SquareMatrixTpl ( const float  M16f[],
bool  rotationOnly = false
inline
The matrix dimension is automatically set to 4. It can be forced to 3 (size_3 = true). In this case, only the rotation part will be 'imported'.
Parameters
M16fa table of 16 floats (OpenGL float transformation matrix)
rotationOnlyconsider only the roation part (3x3 matrix)
◆ SquareMatrixTpl() [6/6]
CCCoreLib::SquareMatrixTpl< Scalar >::SquareMatrixTpl ( const double  M16d[],
inline
Parameters
M16da table of 16 floats (OpenGL double transformation matrix)
Member Function Documentation
◆ apply() [1/3]
void CCCoreLib::SquareMatrixTpl< Scalar >::apply ( const double  vec[],
double  result[]
) const
inline
Vec must have the same size as this matrix.
Parameters
vecinput vector
resultoutput vector (= M * vec)
◆ apply() [2/3]
void CCCoreLib::SquareMatrixTpl< Scalar >::apply ( const float  vec[],
double  result[]
) const
inline
Parameters
vecinput vector
◆ apply() [3/3]
float  result[]
) const
inline
Parameters
vecinput vector
◆ initFromQuaternion() [1/2]
void CCCoreLib::SquareMatrixTpl< Scalar >::initFromQuaternion ( const double  q[])
inline
Quaternion is composed of 4 values: an angle (cos(alpha/2)) and an axis (sin(alpha/2)*unit vector).
Parameters
qnormalized quaternion (w,x,y,z)
◆ initFromQuaternion() [2/2]
void CCCoreLib::SquareMatrixTpl< Scalar >::initFromQuaternion ( const float  q[])
inline
Shortcut to double version of initFromQuaternion)
Parameters
qnormalized quaternion (4 float values)
◆ invalidate()
void CCCoreLib::SquareMatrixTpl< Scalar >::invalidate ( )
inline
Invalidates matrix.
Size is reset to 0.
◆ isValid()
bool CCCoreLib::SquareMatrixTpl< Scalar >::isValid ( ) const
inline
Matrix is invalid if its size is 0!
◆ print()
void CCCoreLib::SquareMatrixTpl< Scalar >::print ( FILE *  fp = nullptr) const
inline
Parameters
fpASCII FILE handle (or 0 to print to console)
◆ toQuaternion()
bool CCCoreLib::SquareMatrixTpl< Scalar >::toQuaternion ( double  q[])
inline
Warning: for 3x3 matrix only! From libE57 'best practices' (http://www.libe57.org/best.html)
Parameters
qquaternion (w,x,y,z)
Returns
success
Member Data Documentation
◆ m_values
Scalar** CCCoreLib::SquareMatrixTpl< Scalar >::m_values = nullptr
The matrix rows.
public for easy/fast access
The documentation for this class was generated from the following file:
