CCCoreLib 31 May 2022
CloudCompare Core algorithms
Public Member Functions | Public Attributes | List of all members
CCCoreLib::DgmOctree::NearestNeighboursSearchStruct Struct Reference
Container of in/out parameters for nearest neighbour(s) search. More...
#include <DgmOctree.h>
Collaboration diagram for CCCoreLib::DgmOctree::NearestNeighboursSearchStruct:
Collaboration graph
[legend]
 NearestNeighboursSearchStruct ()
Public Attributes
CCVector3 queryPoint
 Query point. More...
unsigned char level
 Level of subdivision of the octree at which to start the search. More...
unsigned minNumberOfNeighbors
 Minimal number of neighbours to find. More...
Tuple3i cellPos
 Position in the octree of the cell including the query point. More...
CCVector3 cellCenter
 Coordinates of the center of the cell including the query point. More...
double maxSearchSquareDistd
 Maximum neihgbours distance. More...
cellIndexesContainer minimalCellsSetToVisit
 List of indexes of the cells that have been already visited by the algorithm. More...
NeighboursSet pointsInNeighbourhood
 All the points that belong to the cubical neighbourhood of the current cell. More...
int alreadyVisitedNeighbourhoodSize
 Size of the cell neighbourhood that has been already visited by the algorithm. More...
unsigned theNearestPointIndex
 The nearest point. More...
Detailed Description
This structure is generic and can be used in multiple cases. It is particularly useful when searching nearest neighbours around points that lie in the same octree cell. In this case, several informations about this cell should be given to the search algorithm through this structure, but only once,before the first search. Then the search algorithm can be called multiple times, and only few informations need to be updated (the query point, etc.).
Member Data Documentation
◆ alreadyVisitedNeighbourhoodSize
int CCCoreLib::DgmOctree::NearestNeighboursSearchStruct::alreadyVisitedNeighbourhoodSize
This field is updated by the search algorithm. It should only be reset to 0 when the cell that includes the query point changes. A value of 0 means that no cell has been visited yet, 1 means that only the cell that includes the query point has been visited, 2 means that this cell and its 27 neighbourhing cells have been visited, etc.
◆ cellCenter
CCVector3 CCCoreLib::DgmOctree::NearestNeighboursSearchStruct::cellCenter
Use DgmOctree::computeCellCenter to determine these coordinates. This information should only be updated if the cell changes.
◆ cellPos
Tuple3i CCCoreLib::DgmOctree::NearestNeighboursSearchStruct::cellPos
The position is expressed for the level of subdivision at which the search will be processed. Use see DgmOctree::getCellPos to determine this position. This information should only be updated if the cell changes.
◆ level
unsigned char CCCoreLib::DgmOctree::NearestNeighboursSearchStruct::level
Should be set once and for all.
◆ maxSearchSquareDistd
double CCCoreLib::DgmOctree::NearestNeighboursSearchStruct::maxSearchSquareDistd
The NN search process will stop if it reaches this radius even if it hasn't find any neighbour (acceleration). To disable this behavior, set the maxSearchSquareDistd to something <= 0).
◆ minimalCellsSetToVisit
cellIndexesContainer CCCoreLib::DgmOctree::NearestNeighboursSearchStruct::minimalCellsSetToVisit
This field is updated by the search algorithm. It should only be emptied if the cell that includes the query points change. Only used by the "unique nearest point" search algorithm.
◆ minNumberOfNeighbors
unsigned CCCoreLib::DgmOctree::NearestNeighboursSearchStruct::minNumberOfNeighbors
used only during multiple neighbours search (see findNearestNeighborsStartingFromCell). This is only indicative and not guaranteed.
◆ pointsInNeighbourhood
NeighboursSet CCCoreLib::DgmOctree::NearestNeighboursSearchStruct::pointsInNeighbourhood
This structure is only used by the "multiple nearest neighbours" search algorithms. The nearest points (relatively to the query point) are stored at the beginning of the vector. They are associated to their square distance to the query point.
◆ queryPoint
CCVector3 CCCoreLib::DgmOctree::NearestNeighboursSearchStruct::queryPoint
Query point.
Should be updated each time.
◆ theNearestPointIndex
unsigned CCCoreLib::DgmOctree::NearestNeighboursSearchStruct::theNearestPointIndex
The nearest point.
This field is only used by the "unique nearest neighbour" search algorithm (see DgmOctree::findTheNearestNeighborStartingFromCell).
The documentation for this struct was generated from the following file:
