CCCoreLib 31 May 2022
CloudCompare Core algorithms
Cloud-to-mesh distances computation parameters. More...
#include <DistanceComputationTools.h>
Cloud2MeshDistancesComputationParams () | |
Default constructor. | |
Public Attributes | |
unsigned char | octreeLevel |
The level of subdivision of the octree at witch to apply the algorithm. | |
ScalarType | maxSearchDist |
Max search distance (acceleration) More... | |
bool | useDistanceMap |
Use distance map (acceleration) More... | |
bool | signedDistances |
Whether to compute signed distances or not. More... | |
bool | flipNormals |
Whether triangle normals should be computed in the 'direct' order (true) or 'indirect' (false) | |
bool | multiThread |
Whether to use multi-thread or single thread mode (if maxSearchDist > 0, single thread mode is forced) | |
int | maxThreadCount |
Maximum number of threads to use (0 = max) | |
PointCloud * | CPSet |
Cloud to store the Closest Point Set. More... | |
PointCloud* CCCoreLib::DistanceComputationTools::Cloud2MeshDistancesComputationParams::CPSet |
The cloud should be initialized but empty on input. It will have the same size as the compared cloud on output.
ScalarType CCCoreLib::DistanceComputationTools::Cloud2MeshDistancesComputationParams::maxSearchDist |
Default value: 0. If greater than 0, then the algorithm won't compute distances over this value
bool CCCoreLib::DistanceComputationTools::Cloud2MeshDistancesComputationParams::signedDistances |
If true, the computed distances will be signed (in this case, the Distance Transform can't be used and therefore useDistanceMap will be ignored)
bool CCCoreLib::DistanceComputationTools::Cloud2MeshDistancesComputationParams::useDistanceMap |
If true the distances will be aproximated by a Distance Transform.
