Cross section for multiple slices
Posted: Fri Apr 15, 2022 9:06 am
by EnchantedCJ
Dear guys,
I'm new to the cross section tool, so I try to follow the tutorial in
https://www.cloudcompare.org/doc/wiki/i ... ngle_slice
What I try to produce is several envelope polylines in each slice, but I always get envelops that are connected to each other, which I show in the attachment. However, in the very last picuture in the tutorial (down below the page in the above link), the envelope of the monster's legs seams to be separated. I wonder how to achieve that. Thanks!
Best,
Sun
Re: Cross section for multiple slices
Posted: Sat Apr 16, 2022 9:37 pm
Have you tried the new 'extract contour' tool in the 2.12 version? It's the way to go if you want multiple contours (for each 'island').
Otherwise, the envelope is always unique inside a slice.
Posted: Mon Apr 18, 2022 7:35 am
by EnchantedCJ
daniel wrote: Sat Apr 16, 2022 9:37 pm
Thank you, Daniel. I've tried "extract contour" and that works fine. BTW, I found that the generated contours are zig-zag in a few discrete directions (0,45,90...degree), is this a feature of the tool and cannot generate boundaries with arbitrary directions like the "envelope"?
Posted: Mon Apr 18, 2022 6:43 pm
I guess it depends on the grid step? (but I may misunderstand what happens ;)
Posted: Wed Apr 20, 2022 5:38 am
by EnchantedCJ
daniel wrote: Mon Apr 18, 2022 6:43 pm
Sorry, I haven't made my problem clear. I upload the result in the attachment. The envelop (green line) is extending into arbitrary directions, while the contour (white line) goes in several regular directions. I think you mean this is caused by the gridding calculation of the contour, is that true? Thanks.
Posted: Wed Apr 27, 2022 6:42 am
Yes, the 2 methods have very different ways of working. One projects the points inside a plane and use an expansive algorithm to try to determine the concave hull, and the other simply relies on a regular grid (just as the 'Rasterize' tool).
Posted: Fri Apr 29, 2022 7:32 am
by EnchantedCJ
daniel wrote: Wed Apr 27, 2022 6:42 am
Thank you for your reply! Now I understand how it works.
