Fast Marching algorithm (front propagation)
More...
#include <FastMarching.h>
unsigned | pos2index (const Tuple3i &pos) const |
virtual int | initGridWithOctree (DgmOctree *octree, unsigned char gridLevel) |
| Intializes the grid as a snapshot of an octree structure at a given subdivision level. More...
virtual int | initGrid (float step, unsigned dim[3]) |
| Intializes the grid with a given step and dimensions. More...
virtual int | initOther () |
| Intializes other dimension-related variables and finishes the initialization job.
virtual float | computeT (unsigned index) |
| Computes the front arrival time at a given cell. More...
virtual float | computeTCoefApprox (Cell *currentCell, Cell *neighbourCell) const =0 |
| Computes the front acceleration between two cells. More...
virtual int | step ()=0 |
| Propagates the front (one step) More...
virtual void | initTrialCells () |
| Initializes the TRIAL cells list. More...
virtual bool | instantiateGrid (unsigned size)=0 |
| Instantiates grid in memory. More...
template<class T > |
bool | instantiateGridTpl (unsigned size) |
| Grid instantiation helper.
virtual void | addTrialCell (unsigned index) |
| Add a cell to the TRIAL cells list. More...
virtual void | addActiveCell (unsigned index) |
| Add a cell to the ACTIVE cells list. More...
virtual void | addIgnoredCell (unsigned index) |
| Add a cell to the IGNORED cells list. More...
virtual unsigned | getNearestTrialCell () |
| Returns the TRIAL cell with the smallest front arrival time. More...
void | resetCells (std::vector< unsigned > &list) |
| Resets the state of cells in a given list. More...
std::vector< unsigned > | m_activeCells |
| ACTIVE cells list.
std::vector< unsigned > | m_trialCells |
| TRIAL cells list.
std::vector< unsigned > | m_ignoredCells |
| IGNORED cells lits.
bool | m_initialized |
| Specifiies whether structure is initialized or not.
unsigned | m_dx |
| Grid size along the X dimension.
unsigned | m_dy |
| Grid size along the Y dimension.
unsigned | m_dz |
| Grid size along the Z dimension.
unsigned | m_rowSize |
| Shift for cell access acceleration (Y dimension)
unsigned | m_sliceSize |
| Shift for cell access acceleration (Z dimension)
unsigned | m_indexShift |
| First index of innerbound grid.
unsigned | m_gridSize |
| Grid size.
Cell ** | m_theGrid |
| Grid used to process Fast Marching.
DgmOctree * | m_octree |
| Associated octree.
unsigned char | m_gridLevel |
| Equivalent octree subdivision level.
float | m_cellSize |
| Octree cell size at equivalent subdivision level.
Tuple3i | m_minFillIndexes |
| Octree min fill indexes at 'm_gridLevel'.
unsigned | m_numberOfNeighbours |
| Current number of neighbours (6 or 26)
int | m_neighboursIndexShift [CC_FM_MAX_NUMBER_OF_NEIGHBOURS] |
| Neighbours coordinates shifts in grid.
float | m_neighboursDistance [CC_FM_MAX_NUMBER_OF_NEIGHBOURS] |
| Neighbours distance weight.
Implementation of the Fast Marching algorithm [Sethian 1996]. Inspired from the "vtkFastMarching" class of the "Slicer" project (http://www.slicer.org).
◆ addActiveCell()
void FastMarching::addActiveCell |
unsigned |
index | ) |
protectedvirtual |
- Parameters
◆ addIgnoredCell()
void FastMarching::addIgnoredCell |
unsigned |
index | ) |
protectedvirtual |
- Parameters
◆ addTrialCell()
void FastMarching::addTrialCell |
unsigned |
index | ) |
protectedvirtual |
- Parameters
◆ cleanLastPropagation()
void FastMarching::cleanLastPropagation |
virtual |
Finalizes an iteration process Resets the different lists and the grid. This method should be called after each propagation (before starting a new one).
◆ computeT()
float FastMarching::computeT |
unsigned |
index | ) |
protectedvirtual |
the cell is represented by its index in the cell list
- Parameters
- Returns
- the computed front arrival time
◆ computeTCoefApprox()
virtual float CCCoreLib::FastMarching::computeTCoefApprox |
Cell * |
currentCell, |
Cell * |
neighbourCell |
| const |
protectedpure virtual |
- Parameters
currentCell | the "central" cell |
neighbourCell | the other cell |
- Returns
- the front acceleration
Implemented in CCCoreLib::FastMarchingForPropagation.
◆ getNearestTrialCell()
unsigned FastMarching::getNearestTrialCell |
protectedvirtual |
- Returns
- the index of the "earliest" TRIAL cell (or 0 in case of error)
◆ getTime()
float FastMarching::getTime |
Tuple3i & |
pos, |
bool |
absoluteCoordinates = false |
| const |
virtual |
Returns the front arrival time at a given cell.
This method should only be called after the propagation succeeded. The coordinates of the cell can be absolute (i.e. expressed relatively to the octree borders) or relative (i.e. expressed relatively to the Fast Marching grid).
- Parameters
pos | the cell position (3 integer coordinates) |
absoluteCoordinates | whether the cell coordinates are absolute or relative |
◆ initGrid()
int FastMarching::initGrid |
float |
step, |
unsigned |
dim[3] |
protectedvirtual |
- Parameters
step | grid step |
dim | grid dimensions in 3D |
- Returns
- a negative value if a problem occurred
◆ initGridWithOctree()
int FastMarching::initGridWithOctree |
DgmOctree * |
octree, |
unsigned char |
gridLevel |
protectedvirtual |
- Parameters
octree | input octree |
gridLevel | subdivision level |
- Returns
◆ initTrialCells()
void FastMarching::initTrialCells |
protectedvirtual |
See the Fast Marching algorithm theory for more information
◆ instantiateGrid()
virtual bool CCCoreLib::FastMarching::instantiateGrid |
unsigned |
size | ) |
◆ propagate()
virtual int CCCoreLib::FastMarching::propagate |
pure virtual |
◆ resetCells()
void FastMarching::resetCells |
std::vector< unsigned > & |
list | ) |
protected |
Warning: the list will be cleared!
◆ setExtendedConnectivity()
virtual void CCCoreLib::FastMarching::setExtendedConnectivity |
bool |
state | ) |
inlinevirtual |
Sets extended connectivity mode.
To use common edges instead of common faces (much slower)
◆ setSeedCell()
bool FastMarching::setSeedCell |
const Tuple3i & |
pos | ) |
virtual |
Sets a given cell as "seed".
- Parameters
pos | the cell position in the grid (3 integer coordinates) |
- Returns
- whether the cell could be set as a seed or not
◆ step()
virtual int CCCoreLib::FastMarching::step |
- FastMarching.h
- FastMarching.cpp
