CCCoreLib 31 May 2022
CloudCompare Core algorithms
Fast Marching algorithm for surface front propagation. More...
#include <FastMarchingForPropagation.h>
Classes | |
class | PropagationCell |
A Fast Marching grid cell for surfacical propagation. More... | |
FastMarchingForPropagation () | |
Default constructor. | |
int | init (GenericCloud *theCloud, DgmOctree *theOctree, unsigned char gridLevel, bool constantAcceleration=false) |
Initializes the grid with a point cloud (and ist corresponding octree) More... | |
bool | extractPropagatedPoints (ReferenceCloud *Zk) |
Returns a list of the points (references to) reached by the propagation process. More... | |
bool | setPropagationTimingsAsDistances () |
Sets the propagation timings as distances for each point. More... | |
void | setDetectionThreshold (float value) |
Sets the threshold for propagation stop. More... | |
void | setJumpCoef (float value) |
Sets the accceleration exageration factor. More... | |
void | findPeaks () |
Find peaks of local acceleration values. More... | |
int | propagate () override |
Propagates the front. More... | |
Public Member Functions inherited from CCCoreLib::FastMarching | |
FastMarching () | |
virtual | ~FastMarching () |
Destructor. | |
virtual bool | setSeedCell (const Tuple3i &pos) |
Sets a given cell as "seed". More... | |
virtual int | propagate ()=0 |
virtual void | cleanLastPropagation () |
virtual float | getTime (Tuple3i &pos, bool absoluteCoordinates=false) const |
Returns the front arrival time at a given cell. More... | |
virtual void | setExtendedConnectivity (bool state) |
Sets extended connectivity mode. More... | |
float | computeTCoefApprox (Cell *currentCell, Cell *neighbourCell) const override |
Computes the front acceleration between two cells. More... | |
int | step () override |
Propagates the front (one step) More... | |
bool | instantiateGrid (unsigned size) override |
Instantiates grid in memory. More... | |
Protected Member Functions inherited from CCCoreLib::FastMarching | |
unsigned | pos2index (const Tuple3i &pos) const |
virtual int | initGridWithOctree (DgmOctree *octree, unsigned char gridLevel) |
Intializes the grid as a snapshot of an octree structure at a given subdivision level. More... | |
virtual int | initGrid (float step, unsigned dim[3]) |
Intializes the grid with a given step and dimensions. More... | |
virtual int | initOther () |
Intializes other dimension-related variables and finishes the initialization job. | |
virtual float | computeT (unsigned index) |
Computes the front arrival time at a given cell. More... | |
virtual float | computeTCoefApprox (Cell *currentCell, Cell *neighbourCell) const =0 |
virtual int | step ()=0 |
virtual void | initTrialCells () |
Initializes the TRIAL cells list. More... | |
virtual bool | instantiateGrid (unsigned size)=0 |
template<class T > | |
bool | instantiateGridTpl (unsigned size) |
Grid instantiation helper. | |
virtual void | addTrialCell (unsigned index) |
Add a cell to the TRIAL cells list. More... | |
virtual void | addActiveCell (unsigned index) |
Add a cell to the ACTIVE cells list. More... | |
virtual void | addIgnoredCell (unsigned index) |
Add a cell to the IGNORED cells list. More... | |
virtual unsigned | getNearestTrialCell () |
Returns the TRIAL cell with the smallest front arrival time. More... | |
void | resetCells (std::vector< unsigned > &list) |
Resets the state of cells in a given list. More... | |
float | m_jumpCoef |
Accceleration exageration factor. | |
float | m_detectionThreshold |
Threshold for propagation stop. | |
Protected Attributes inherited from CCCoreLib::FastMarching | |
std::vector< unsigned > | m_activeCells |
ACTIVE cells list. | |
std::vector< unsigned > | m_trialCells |
TRIAL cells list. | |
std::vector< unsigned > | m_ignoredCells |
IGNORED cells lits. | |
bool | m_initialized |
Specifiies whether structure is initialized or not. | |
unsigned | m_dx |
Grid size along the X dimension. | |
unsigned | m_dy |
Grid size along the Y dimension. | |
unsigned | m_dz |
Grid size along the Z dimension. | |
unsigned | m_rowSize |
Shift for cell access acceleration (Y dimension) | |
unsigned | m_sliceSize |
Shift for cell access acceleration (Z dimension) | |
unsigned | m_indexShift |
First index of innerbound grid. | |
unsigned | m_gridSize |
Grid size. | |
Cell ** | m_theGrid |
Grid used to process Fast Marching. | |
DgmOctree * | m_octree |
Associated octree. | |
unsigned char | m_gridLevel |
Equivalent octree subdivision level. | |
float | m_cellSize |
Octree cell size at equivalent subdivision level. | |
Tuple3i | m_minFillIndexes |
Octree min fill indexes at 'm_gridLevel'. | |
unsigned | m_numberOfNeighbours |
Current number of neighbours (6 or 26) | |
int | m_neighboursIndexShift [CC_FM_MAX_NUMBER_OF_NEIGHBOURS] |
Neighbours coordinates shifts in grid. | |
float | m_neighboursDistance [CC_FM_MAX_NUMBER_OF_NEIGHBOURS] |
Neighbours distance weight. | |
Extends the FastMarching class.
overrideprotectedvirtual |
currentCell | the "central" cell |
neighbourCell | the other cell |
Implements CCCoreLib::FastMarching.
bool FastMarchingForPropagation::extractPropagatedPoints | ( | ReferenceCloud * | Zk | ) |
Returns a cloud of points (references to) corresponding to the points that are lying in cells that have been visited by the last propagation process.
[out] | Zk | (reference) point cloud |
void FastMarchingForPropagation::findPeaks | ( | ) |
This method is useful when using this Fast Marching algorithm in a Watershed process. Peak cells are automatically set as "seeds".
int FastMarchingForPropagation::init | ( | GenericCloud * | theCloud, |
DgmOctree * | theOctree, | ||
unsigned char | gridLevel, | ||
bool | constantAcceleration = false |
The points should be associated to scalar values. Warning: be sure to activate an OUTPUT scalar field on the input cloud The Fast Marching grid will have the same characteristics as the octree considered at a given level of subdivision. The local front acceleration in each cell is deduced from the scalar values associated to the points lying in the octree cell (mean value).
theCloud | the point cloud |
theOctree | the associated octree |
gridLevel | the level of subdivision |
constantAcceleration | specifies if the acceleration is constant or shoul be computed from the cell points scalar values |
inlineoverrideprotectedvirtual |
Grid is also filled with zeros.
size | grid size |
overridevirtual |
The seeds should have already been initialized
inline |
This threshold corresponds to the maximum front arrival time increase allowed. If the delta between the fornt arrival time at two consecutive cells is higher, the propagation process is stoped.
value | the threshold |
inline |
In order to detect the front arrival time jumps (see FastMarchingForPropagation::setDetectionThreshold), it is possible to exaggerate the result of the acceleration computation with this factor.
value | the acceleration exageration factor |
bool FastMarchingForPropagation::setPropagationTimingsAsDistances | ( | ) |
