CCCoreLib 31 May 2022
CloudCompare Core algorithms
A generic 3D point cloud interface for data communication between library and client applications. More...
#include <GenericCloud.h>
Public Types | |
using | genericPointAction = std::function< void(const CCVector3 &, ScalarType &)> |
Generic function applied to a point (used by foreach) | |
GenericCloud ()=default | |
Default constructor. | |
virtual | ~GenericCloud ()=default |
Default destructor. | |
virtual unsigned | size () const =0 |
Returns the number of points. More... | |
virtual void | forEach (genericPointAction action)=0 |
Fast iteration mechanism. More... | |
virtual void | getBoundingBox (CCVector3 &bbMin, CCVector3 &bbMax)=0 |
Returns the cloud bounding box. More... | |
virtual unsigned char | testVisibility (const CCVector3 &P) const |
Returns a given point visibility state (relatively to a sensor for instance) More... | |
virtual void | placeIteratorAtBeginning ()=0 |
Sets the cloud iterator at the beginning. More... | |
virtual const CCVector3 * | getNextPoint ()=0 |
Returns the next point (relatively to the global iterator position) More... | |
virtual bool | enableScalarField ()=0 |
Enables the scalar field associated to the cloud. More... | |
virtual bool | isScalarFieldEnabled () const =0 |
Returns true if the scalar field is enabled, false otherwise. More... | |
virtual void | setPointScalarValue (unsigned pointIndex, ScalarType value)=0 |
Sets the ith point associated scalar value. More... | |
virtual ScalarType | getPointScalarValue (unsigned pointIndex) const =0 |
Returns the ith point associated scalar value. More... | |
pure virtual |
If the scalar field structure is not yet initialized/allocated, this method gives the signal for its creation. Otherwise, if possible the structure size should be pre-reserved with the same number of elements as the point cloud.
Implemented in CCCoreLib::DgmOctreeReferenceCloud, and CCCoreLib::ReferenceCloud.
pure virtual |
Virtual method to apply a function to the whole cloud
action | the function to apply (see GenericCloud::genericPointAction) |
pure virtual |
Virtual method to request the cloud bounding box limits
bbMin | lower bounding-box limits (Xmin,Ymin,Zmin) |
bbMax | higher bounding-box limits (Xmax,Ymax,Zmax) |
pure virtual |
Virtual method to handle the cloud global iterator. Global iterator position should be increased by one each time this method is called. Warning:
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
Virtual method to request the cloud size
inlinevirtual |
Generic method to request a point visibility (should be overloaded if this functionality is required). The point visibility is such as defined in Daniel Girardeau-Montaut's PhD manuscript (see Chapter 2, section 2-3-3). In this case, a ground based laser sensor model should be used to determine it. This method is called before performing any point-to-cloud comparison. If the result is not POINT_VISIBLE, then the comparison won't be performed and the scalar field value associated to this point will be this visibility value.
P | the 3D point to test |
Reimplemented in CCCoreLib::ReferenceCloud.
