CCCoreLib 31 May 2022
CloudCompare Core algorithms
A very simple point cloud (no point duplication) More...
#include <ReferenceCloud.h>
ReferenceCloud (GenericIndexedCloudPersist *associatedCloud) | |
Default constructor. | |
ReferenceCloud (const ReferenceCloud &refCloud) | |
Copy constructor. | |
~ReferenceCloud () override=default | |
Destructor. | |
Returns the number of points. More... | |
void | forEach (genericPointAction action) override |
Fast iteration mechanism. More... | |
Returns the cloud bounding box. More... | |
unsigned char | testVisibility (const CCVector3 &P) const override |
Returns a given point visibility state (relatively to a sensor for instance) More... | |
Sets the cloud iterator at the beginning. More... | |
const CCVector3 * | getNextPoint () override |
Returns the next point (relatively to the global iterator position) More... | |
bool | enableScalarField () override |
Enables the scalar field associated to the cloud. More... | |
bool | isScalarFieldEnabled () const override |
Returns true if the scalar field is enabled, false otherwise. More... | |
void | setPointScalarValue (unsigned pointIndex, ScalarType value) override |
Sets the ith point associated scalar value. More... | |
ScalarType | getPointScalarValue (unsigned pointIndex) const override |
Returns the ith point associated scalar value. More... | |
const CCVector3 * | getPoint (unsigned index) const override |
Returns the ith point. More... | |
void | getPoint (unsigned index, CCVector3 &P) const override |
Returns whether normals are available. More... | |
const CCVector3 * | getNormal (unsigned index) const override |
If per-point normals are available, returns the one at a specific index. More... | |
const CCVector3 * | getPointPersistentPtr (unsigned index) const override |
Returns the ith point as a persistent pointer. More... | |
virtual unsigned | getPointGlobalIndex (unsigned localIndex) const |
Returns global index (i.e. relative to the associated cloud) of a given element. More... | |
virtual const CCVector3 * | getCurrentPointCoordinates () const |
Returns the coordinates of the point pointed by the current element. More... | |
virtual unsigned | getCurrentPointGlobalIndex () const |
Returns the global index of the point pointed by the current element. | |
virtual ScalarType | getCurrentPointScalarValue () const |
Returns the current point associated scalar value. | |
virtual void | setCurrentPointScalarValue (ScalarType value) |
Sets the current point associated scalar value. | |
virtual void | forwardIterator () |
Forwards the local element iterator. | |
virtual void | clear (bool releaseMemory=false) |
Clears the cloud. More... | |
virtual bool | addPointIndex (unsigned globalIndex) |
Point global index insertion mechanism. More... | |
virtual bool | addPointIndex (unsigned firstIndex, unsigned lastIndex) |
Point global index insertion mechanism (range) More... | |
virtual void | setPointIndex (unsigned localIndex, unsigned globalIndex) |
Sets global index for a given element. More... | |
virtual bool | reserve (unsigned n) |
Reserves some memory for hosting the point references. More... | |
virtual bool | resize (unsigned n) |
Presets the size of the vector used to store point references. More... | |
virtual unsigned | capacity () const |
Returns max capacity. | |
virtual void | swap (unsigned i, unsigned j) |
Swaps two point references. More... | |
virtual void | removeCurrentPointGlobalIndex () |
Removes current element. More... | |
virtual void | removePointGlobalIndex (unsigned localIndex) |
Removes a given element. More... | |
virtual GenericIndexedCloudPersist * | getAssociatedCloud () |
Returns the associated (source) cloud. | |
virtual const GenericIndexedCloudPersist * | getAssociatedCloud () const |
Returns the associated (source) cloud (const version) | |
virtual void | setAssociatedCloud (GenericIndexedCloudPersist *cloud) |
Sets the associated (source) cloud. | |
bool | add (const ReferenceCloud &cloud) |
Add another reference cloud. More... | |
void | invalidateBoundingBox () |
Invalidates the bounding-box. | |
Public Member Functions inherited from CCCoreLib::GenericIndexedCloudPersist | |
GenericIndexedCloudPersist ()=default | |
GenericIndexedCloudPersist (const char *name, unsigned ID) | |
Mock constructor for compatibility with the PointCloudTpl interface. More... | |
~GenericIndexedCloudPersist () override=default | |
Default destructor. | |
virtual const CCVector3 * | getPointPersistentPtr (unsigned index) const =0 |
Public Member Functions inherited from CCCoreLib::GenericIndexedCloud | |
GenericIndexedCloud ()=default | |
~GenericIndexedCloud () override=default | |
virtual const CCVector3 * | getPoint (unsigned index) const =0 |
virtual void | getPoint (unsigned index, CCVector3 &P) const =0 |
virtual bool | normalsAvailable () const |
virtual const CCVector3 * | getNormal (unsigned index) const |
Public Member Functions inherited from CCCoreLib::GenericCloud | |
GenericCloud ()=default | |
virtual | ~GenericCloud ()=default |
virtual unsigned | size () const =0 |
virtual void | forEach (genericPointAction action)=0 |
virtual void | getBoundingBox (CCVector3 &bbMin, CCVector3 &bbMax)=0 |
virtual unsigned char | testVisibility (const CCVector3 &P) const |
virtual void | placeIteratorAtBeginning ()=0 |
virtual const CCVector3 * | getNextPoint ()=0 |
virtual bool | enableScalarField ()=0 |
virtual bool | isScalarFieldEnabled () const =0 |
virtual void | setPointScalarValue (unsigned pointIndex, ScalarType value)=0 |
virtual ScalarType | getPointScalarValue (unsigned pointIndex) const =0 |
Protected Types | |
using | ReferencesContainer = std::vector< unsigned int > |
Container of 3D point indexes. | |
ReferencesContainer | m_theIndexes |
Indexes of (some of) the associated cloud points. | |
std::atomic< unsigned > | m_globalIterator |
Iterator on the point references container. | |
BoundingBox | m_bbox |
Bounding-box. | |
GenericIndexedCloudPersist * | m_theAssociatedCloud |
Associated cloud. More... | |
std::mutex | m_mutex |
For concurrent access. | |
Public Types inherited from CCCoreLib::GenericCloud | |
using | genericPointAction = std::function< void(const CCVector3 &, ScalarType &)> |
Generic function applied to a point (used by foreach) | |
Implements the GenericIndexedCloudPersist interface. A simple point cloud that stores references to Generic3dPoint instances in a vector.
Partial thread safety for all methods that can change the size of the cloud or that change or rely on point ordering.
bool ReferenceCloud::add | ( | const ReferenceCloud & | cloud | ) |
virtual |
firstIndex | first point global index of range |
lastIndex | last point global index of range (excluded) |
virtual |
globalIndex | a point global index |
virtual |
If the scalar field structure is not yet initialized/allocated, this method gives the signal for its creation. Otherwise, if possible the structure size should be pre-reserved with the same number of elements as the point cloud.
Implements CCCoreLib::GenericCloud.
overridevirtual |
Virtual method to apply a function to the whole cloud
action | the function to apply (see GenericCloud::genericPointAction) |
Virtual method to request the cloud bounding box limits
bbMin | lower bounding-box limits (Xmin,Ymin,Zmin) |
bbMax | higher bounding-box limits (Xmax,Ymax,Zmax) |
virtual |
Returns a persistent pointer.
Virtual method to handle the cloud global iterator. Global iterator position should be increased by one each time this method is called. Warning:
Reimplemented from CCCoreLib::GenericIndexedCloud.
Virtual method to request a point with a specific index. WARNINGS:
index | of the requested point (between 0 and the cloud size minus 1) |
Implements CCCoreLib::GenericIndexedCloud.
Virtual method to request a point with a specific index. Index must be valid (undefined behavior if index is invalid)
P | output point |
inlinevirtual |
localIndex | local index (i.e. relative to the internal index container) |
Virtual method to request a point with a specific index. WARNING: the returned object MUST be persistent in order to be compatible with parallel strategies!
Implements CCCoreLib::GenericIndexedCloudPersist.
inlinevirtual |
WARNING: this method changes the cloud size! Thread safe.
virtual |
virtual |
n | the number of points (references) Thread safe. |
virtual |
virtual |
localIndex | local index |
globalIndex | global index |
Virtual method to request the cloud size
inlinevirtual |
the point references indexes should be smaller than the total number of "reserved" points (see ReferenceCloud::reserve).
i | the first point index |
j | the second point index Thread safe. |
Generic method to request a point visibility (should be overloaded if this functionality is required). The point visibility is such as defined in Daniel Girardeau-Montaut's PhD manuscript (see Chapter 2, section 2-3-3). In this case, a ground based laser sensor model should be used to determine it. This method is called before performing any point-to-cloud comparison. If the result is not POINT_VISIBLE, then the comparison won't be performed and the scalar field value associated to this point will be this visibility value.
P | the 3D point to test |
Reimplemented from CCCoreLib::GenericCloud.
protected |
Associated cloud.
The cloud from which references are referring to. WARNING: do not use the inner iterator as it is used to 'implement' the ReferenceCloud one.
