CCCoreLib 31 May 2022
CloudCompare Core algorithms
Public Member Functions | Public Attributes | List of all members
CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams Struct Reference
Cloud-to-cloud 'nearest neighbors' distances computation parameters. More...
#include <DistanceComputationTools.h>
Collaboration diagram for CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams:
Collaboration graph
[legend]
 Cloud2CloudDistancesComputationParams ()
 Default constructor/initialization.
Public Attributes
unsigned char octreeLevel
 Level of subdivision of the octree at witch to apply the distance computation algorithm. More...
ScalarType maxSearchDist
 Maximum search distance (true distance won't be computed if greater) More...
bool multiThread
 Whether to use multi-thread or single thread mode. More...
int maxThreadCount
 Maximum number of threads to use (0 = max)
LOCAL_MODEL_TYPES localModel
 Type of local 3D modeling to use. More...
bool useSphericalSearchForLocalModel
 Whether to use a fixed number of neighbors or a (sphere) radius for nearest neighbors search. More...
unsigned kNNForLocalModel
 Number of neighbors for nearest neighbors search (local model) More...
ScalarType radiusForLocalModel
 Radius for nearest neighbors search (local model) More...
bool reuseExistingLocalModels
 Whether to use an approximation for local model computation. More...
ReferenceCloudCPSet
 Container of (references to) points to store the "Closest Point Set". More...
ScalarFieldsplitDistances [3]
 Split distances (one scalar field per dimension: X, Y and Z)
bool resetFormerDistances
 Whether to keep the existing distances as is (if any) or not. More...
Detailed Description
Member Data Documentation
◆ CPSet
ReferenceCloud* CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::CPSet
The Closest Point Set corresponds to (the reference to) each compared point's closest neighbor.
Warning
Not compatible with max search distance (see maxSearchDist)
◆ kNNForLocalModel
unsigned CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::kNNForLocalModel
For local models only (i.e. ignored if localModel = NO_MODEL). Ignored if useSphericalSearchForLocalModel is true.
◆ localModel
LOCAL_MODEL_TYPES CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::localModel
Default: NO_MODEL. Otherwise see CC_LOCAL_MODEL_TYPES.
◆ maxSearchDist
ScalarType CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::maxSearchDist
Set to -1 to deactivate (default).
Warning
Not compatible with closest point set determination (see CPSet)
◆ multiThread
bool CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::multiThread
If maxSearchDist > 0, single thread mode will be forced.
◆ octreeLevel
unsigned char CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::octreeLevel
If set to 0 (default) the algorithm will try to guess the best level automatically.
◆ radiusForLocalModel
ScalarType CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::radiusForLocalModel
◆ resetFormerDistances
bool CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::resetFormerDistances
By default, any previous distances/scalar values stored in the 'enabled' scalar field will be reset before computing them again.
◆ reuseExistingLocalModels
bool CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::reuseExistingLocalModels
For local models only (i.e. ignored if localModel = NO_MODEL). Computation is much faster but less "controlled".
◆ useSphericalSearchForLocalModel
bool CCCoreLib::DistanceComputationTools::Cloud2CloudDistancesComputationParams::useSphericalSearchForLocalModel
The documentation for this struct was generated from the following file:
