Several point cloud resampling algorithms (octree-based, random, etc.)
More...
#include <CloudSamplingTools.h>
static PointCloud * | resampleCloudWithOctreeAtLevel (GenericIndexedCloudPersist *cloud, unsigned char octreeLevel, RESAMPLING_CELL_METHOD resamplingMethod, GenericProgressCallback *progressCb=nullptr, DgmOctree *inputOctree=nullptr) |
| Resamples a point cloud (process based on the octree) More...
static GenericIndexedCloud * | resampleCloudWithOctree (GenericIndexedCloudPersist *cloud, int newNumberOfPoints, RESAMPLING_CELL_METHOD resamplingMethod, GenericProgressCallback *progressCb=nullptr, DgmOctree *inputOctree=nullptr) |
static ReferenceCloud * | subsampleCloudWithOctreeAtLevel (GenericIndexedCloudPersist *cloud, unsigned char octreeLevel, SUBSAMPLING_CELL_METHOD subsamplingMethod, GenericProgressCallback *progressCb=nullptr, DgmOctree *inputOctree=nullptr) |
| Subsamples a point cloud (process based on the octree) More...
static ReferenceCloud * | subsampleCloudWithOctree (GenericIndexedCloudPersist *cloud, int newNumberOfPoints, SUBSAMPLING_CELL_METHOD subsamplingMethod, GenericProgressCallback *progressCb=nullptr, DgmOctree *inputOctree=nullptr) |
static ReferenceCloud * | subsampleCloudRandomly (GenericIndexedCloudPersist *cloud, unsigned newNumberOfPoints, GenericProgressCallback *progressCb=nullptr) |
| Subsamples a point cloud (process based on random selections) More...
static ReferenceCloud * | resampleCloudSpatially (GenericIndexedCloudPersist *cloud, PointCoordinateType minDistance, const SFModulationParams &modParams, DgmOctree *octree=nullptr, GenericProgressCallback *progressCb=nullptr) |
| Resamples a point cloud (process based on inter point distance) More...
static ReferenceCloud * | sorFilter (GenericIndexedCloudPersist *cloud, int knn=6, double nSigma=1.0, DgmOctree *octree=nullptr, GenericProgressCallback *progressCb=nullptr) |
| Statistical Outliers Removal (SOR) filter. More...
static ReferenceCloud * | noiseFilter (GenericIndexedCloudPersist *cloud, PointCoordinateType kernelRadius, double nSigma, bool removeIsolatedPoints=false, bool useKnn=false, int knn=6, bool useAbsoluteError=true, double absoluteError=0.0, DgmOctree *octree=nullptr, GenericProgressCallback *progressCb=nullptr) |
| Noise filter based on the distance to the approximate local surface. More...
◆ applyNoiseFilterAtLevel()
"Cellular" function to apply the noise filter inside an octree cell
This function is meant to be applied to all cells of the octree (it is of the form DgmOctree::localFunctionPtr).
- Parameters
cell | structure describing the cell on which processing is applied |
additionalParameters | see method description |
nProgress | optional (normalized) progress notification (per-point) |
◆ applySORFilterAtLevel()
"Cellular" function to apply the SOR filter inside an octree cell
- Parameters
◆ noiseFilter()
This filter removes points based on their distance relatively to the best fit plane computed on their neighbors.
- Parameters
cloud | the point cloud to resample |
kernelRadius | neighborhood radius |
nSigma | number of sigmas under which the points should be kept |
removeIsolatedPoints | whether to remove isolated points (i.e. with 3 points or less in the neighborhood) |
useKnn | whether to use a constant number of neighbors instead of a radius |
knn | number of neighbors (if useKnn is true) |
useAbsoluteError | whether to use an absolute error instead of 'n' sigmas |
absoluteError | absolute error (if useAbsoluteError is true) |
octree | associated octree if available |
- Returns
- a reference cloud corresponding to the filtered cloud
◆ resampleCellAtLevel()
"Cellular" function to replace one set of points (contained in an octree cell) by a unique point
This function is meant to be applied to all cells of the octree (it is of the form DgmOctree::localFunctionPtr). It replaces all points in a cell by a unique one, according to different rules. Method parameters (defined in "additionalParameters") are :
- (PointCloud*) point cloud to store new points
- (RESAMPLING_CELL_METHOD*) resampling method
- Parameters
◆ resampleCloudSpatially()
The cloud is resampled so that there is no point nearer than a given distance to other points It works by picking a reference point, removing all points which are to close to this point, and repeating these two steps until the result is reached
- Parameters
minDistance | the distance under which a point in the resulting cloud cannot have any neighbour |
modParams | parameters of the subsampling behavior modulation with a scalar field (optional) |
- Returns
- a reference cloud corresponding to the resampling 'selection'
◆ resampleCloudWithOctree()
Same as 'resampleCloudWithOctreeAtLevel' method, apart the fact that instead of giving a specific octree subdivision level as input parameter, one can specify an approximative number of points for the resulting cloud (algorithm will automatically determine the corresponding octree level).
- Parameters
newNumberOfPoints | desired number of points (approximative) |
resamplingMethod | resampling method (applied to each octree cell) |
inputOctree | if the octree has been already computed, it can be used by the process (avoid recomputation) |
- Returns
- the resampled cloud (new cloud)
◆ resampleCloudWithOctreeAtLevel()
A resampling algorithm is applied inside each cell of the octree. The different resampling methods are represented as an enumerator (see RESAMPLING_CELL_METHOD) and consist in simple processes such as replacing all the points lying in a cell by the cell center or by the points gravity center.
- Parameters
octreeLevel | the octree level at which to perform the resampling process |
- Returns
◆ sorFilter()
This filter removes points based on their mean distance to their distance (by comparing it to the average distance of all points to their neighbors). It is equivalent to PCL StatisticalOutlierRemoval filter (see http://pointclouds.org/documentation/tutorials/statistical_outlier.php)
- Parameters
knn | number of neighbors |
- Returns
◆ subsampleCellAtLevel()
"Cellular" function to select a unique point inside an octree cell
This function is meant to be applied to all cells of the octree (it is of the form DgmOctree::localFunctionPtr). It chooses one point from the set of points inside a cell, according to different rules. Method parameters (defined in "additionalParameters") are :
- (ReferenceCloud*) reference point cloud to store selected points
- (SUBSAMPLING_CELL_METHOD*) subampling method
- Parameters
◆ subsampleCloudRandomly()
A very simple subsampling algorithm that simply consists in selecting "n" different points, in a random way.
- Parameters
cloud | point cloud to subsample |
newNumberOfPoints | desired number of points (exact) |
- Returns
- a reference cloud corresponding to the subsampling 'selection'
◆ subsampleCloudWithOctree()
Same as 'subsampleCloudWithOctreeAtLevel' method, apart the fact that instead of giving a specific octree subdivision level as input parameter, one can specify an approximative number of points for the resulting cloud (algorithm will automatically determine the corresponding octree level).
- Parameters
subsamplingMethod | resampling method (applied to each octree cell) |
- Returns
◆ subsampleCloudWithOctreeAtLevel()
A subsampling algorithm is applied inside each cell of the octree. The different subsampling methods are represented as an enumerator (see SUBSAMPLING_CELL_METHOD) and consist in simple processes such as choosing a random point, or the one closest to the cell center.
- Parameters
octreeLevel | octree level at which to perform the subsampling process |
subsamplingMethod | subsampling method (applied to each octree cell) |
- Returns
- CloudSamplingTools.h
- CloudSamplingTools.cpp
