Four Points Congruent Sets (4PCS) registration algorithm (Dror Aiger, Niloy J. Mitra, Daniel Cohen-Or)
More...
#include <RegistrationTools.h>
static bool | RegisterClouds (GenericIndexedCloud *modelCloud, GenericIndexedCloud *dataCloud, ScaledTransformation &transform, ScalarType delta, ScalarType beta, PointCoordinateType overlap, unsigned nbBases, unsigned nbTries, GenericProgressCallback *progressCb=nullptr, unsigned nbMaxCandidates=0) |
| Registers two point clouds. More...
static void | FilterTransformation (const ScaledTransformation &inTrans, int transformationFilters, ScaledTransformation &outTrans) |
| 'Filters' a transformation by constraining it along certain rotation axes and translation directions More...
static bool | FindBase (GenericIndexedCloud *cloud, PointCoordinateType overlap, unsigned nbTries, Base &base) |
| Randomly finds a 4 points base in a cloud. More...
static int | FindCongruentBases (KDTree *tree, ScalarType delta, const CCVector3 *base[4], std::vector< Base > &results) |
static unsigned | ComputeRegistrationScore (KDTree *modelTree, GenericIndexedCloud *dataCloud, ScalarType delta, const ScaledTransformation &dataToModel) |
| Registration score computation function. More...
static bool | LinesIntersections (const CCVector3 &p0, const CCVector3 &p1, const CCVector3 &p2, const CCVector3 &p3, CCVector3 &inter, PointCoordinateType &lambda, PointCoordinateType &mu) |
| Find the 3D pseudo intersection between two lines. More...
static bool | FilterCandidates (GenericIndexedCloud *modelCloud, GenericIndexedCloud *dataCloud, Base &reference, std::vector< Base > &candidates, unsigned nbMaxCandidates, std::vector< ScaledTransformation > &transforms) |
static bool | RegistrationProcedure (GenericCloud *P, GenericCloud *X, ScaledTransformation &trans, bool adjustScale=false, ScalarField *coupleWeights=nullptr, PointCoordinateType aPrioriScale=1.0f) |
| ICP Registration procedure with optional scale estimation. More...
enum | TRANSFORMATION_FILTERS {
SKIP_NONE = 0
, SKIP_RXY = 1
, SKIP_RYZ = 2
, SKIP_RXZ = 4
SKIP_ROTATION = 7
, SKIP_TX = 8
, SKIP_TY = 16
, SKIP_TZ = 32
SKIP_TRANSLATION = 56
| Transformation constraints.
using | ScaledTransformation = PointProjectionTools::Transformation |
| Shortcut to PointProjectionTools::ScaledTransformation.
◆ ComputeRegistrationScore()
- Parameters
modelTree | KD-tree containing the model point cloud |
dataCloud | data point cloud |
dataToModel | transformation that, applied to data points, register model and data clouds |
delta | tolerance above which data points are not counted (if a point is less than delta-apart from the model cloud, then it is counted) |
- Returns
- the number of data points which are distance-apart from the model cloud
◆ FilterCandidates()
!function to keep only the N best candidates bases (by comparison with the reference base invariants) Let B1 and B2 be 2 candidates, R be the reference, B1 and B2 aligned with R. B1 is better than B2 if the distance between B1 and R points is smaller than distance between B2 and R points. This function also computes and store the rigid transforms that align candidates with reference base
- Parameters
modelCloud | the model point cloud to work on |
dataCloud | the data point cloud to work on |
reference | reference base |
candidates | array of candidates bases. At the end of the function, this array contains the nbMaxBases best candidates only |
nbMaxCandidates | maximal number of candidates allowed (if 0, number of candidates is not bounded) |
transforms | array of rigid transforms that align candidates bases with the reference base |
- Returns
- false if something went wrong
◆ FindBase()
bool FPCSRegistrationTools::FindBase |
GenericIndexedCloud * |
cloud, |
PointCoordinateType |
overlap, |
unsigned |
nbTries, |
Base & |
base |
staticprotected |
- Parameters
cloud | the point cloud in which we want to find a base |
overlap | estimation of the overlap rate |
nbTries | the maximum number of tries to find a base |
base | the resulting base |
- Returns
- false: failure ; true: success
◆ FindCongruentBases()
int FPCSRegistrationTools::FindCongruentBases |
KDTree * |
tree, |
ScalarType |
delta, |
const CCVector3 * |
base[4], |
std::vector< Base > & |
results |
staticprotected |
Find bases which are congruent to a specified 4 points base
- Parameters
tree | the KD-tree build from data cloud |
delta | used for the tolerance when searching for congruent bases |
base | the reference base made of 4 points |
results | the resulting bases |
- Returns
- the number of bases found (number of element in the results array) or -1 is a problem occurred
◆ LinesIntersections()
This function finds the 3D point which is the nearest from the both lines (when this point is unique, i.e. when the lines are not parallel)
- Parameters
p0 | first of the two distinct points defining the first line (lying on the line) |
p1 | second of the two distinct points defining the first line (lying on the line) |
p2 | first of the two distinct points defining the second line |
p3 | first of the two distinct points defining the second line |
inter | [out] is the computed intersection (function output) |
lambda | [out] coeff such that p0+lambda(p1-p0) is the point of [p0, p1] which is the nearest from [p2, p3] |
mu | [out] coeff such that p2+mu(p3-p2) is the point of [p2, p3] which is the nearest from [p0, p1] |
- Returns
- false: no intersection was found (lines may be parallel); true: inter is the pseudo intersection
◆ RegisterClouds()
Implements the 4 Points Congruent Sets Algorithm (Dror Aiger, Niloy J. Mitra, Daniel Cohen-Or
- Parameters
modelCloud | the reference cloud (won't move) |
dataCloud | the cloud to register (will move) |
transform | the resulting transformation (output) |
delta | maximal distance to the reference cloud for the data points to be considered as registered |
beta | is used for bases selection (error tolerance) |
overlap | estimation of the two clouds overlap rate |
nbBases | number of iteration for the algorithm |
nbTries | number of tries to find a base in the reference cloud |
nbMaxCandidates | if>0, maximal number of candidate bases allowed for each step. Otherwise the number of candidates is not bounded |
- Returns
- false: failure ; true: success.
- RegistrationTools.h
- RegistrationTools.cpp
