CCCoreLib 31 May 2022
CloudCompare Core algorithms
A specific point could structure to handle subsets of points, provided with several geometric processings. More...
#include <Neighbourhood.h>
Public Types | |
enum | GeomElement { FLAG_DEPRECATED = 0 , FLAG_GRAVITY_CENTER = 1 , FLAG_LS_PLANE = 2 , FLAG_QUADRIC = 4 } |
Geometric properties/elements that can be computed from the set of points (see Neighbourhood::getGeometricalElement) | |
enum | CurvatureType { GAUSSIAN_CURV = 1 , MEAN_CURV , NORMAL_CHANGE_RATE } |
Curvature type. | |
enum | InputVectorsUsage { UseOXYasBase , UseYAsUpDir , None } |
Defines how input vectors of projectPointsOn2DPlane should be used. | |
enum | GeomFeature { EigenValuesSum = 1 , Omnivariance , EigenEntropy , Anisotropy , Planarity , Linearity , PCA1 , PCA2 , SurfaceVariation , Sphericity , Verticality , EigenValue1 , EigenValue2 , EigenValue3 } |
Geometric feature computed from eigen values/vectors. More... | |
Neighbourhood (GenericIndexedCloudPersist *associatedCloud) | |
virtual | ~Neighbourhood ()=default |
Default destructor. | |
virtual void | reset () |
Resets structure (depreactes all associated geometrical fetaures) | |
GenericIndexedCloudPersist * | associatedCloud () const |
Returns associated cloud. | |
GenericIndexedMesh * | triangulateOnPlane (bool duplicateVertices, PointCoordinateType maxEdgeLength, std::string &outputErrorStr) |
Applies 2D Delaunay triangulation. More... | |
GenericIndexedMesh * | triangulateFromQuadric (unsigned stepsX, unsigned stepsY) |
Fit a quadric on point set (see getQuadric) then triangulates it inside bounding box. | |
template<class Vec2D > | |
bool | projectPointsOn2DPlane (std::vector< Vec2D > &points2D, const PointCoordinateType *planeEquation=nullptr, CCVector3 *O=nullptr, CCVector3 *X=nullptr, CCVector3 *Y=nullptr, InputVectorsUsage vectorsUsage=None) |
Projects points on the best fitting LS plane. More... | |
double | computeFeature (GeomFeature feature) |
Computes the given feature on a set of point. More... | |
ScalarType | computeMomentOrder1 (const CCVector3 &P) |
Computes the 1st order moment of a set of point (based on the eigenvalues) More... | |
ScalarType | computeRoughness (const CCVector3 &P, const CCVector3 *roughnessUpDir=nullptr) |
Computes the roughness of a point (by fitting a 2D plane on its neighbors) More... | |
ScalarType | computeCurvature (const CCVector3 &P, CurvatureType cType) |
Computes the curvature of a set of point (by fitting a 2.5D quadric) More... | |
const CCVector3 * | getGravityCenter () |
Returns gravity center. More... | |
void | setGravityCenter (const CCVector3 &G) |
Sets gravity center. More... | |
const PointCoordinateType * | getLSPlane () |
Returns best interpolating plane equation (Least-square) More... | |
void | setLSPlane (const PointCoordinateType eq[4], const CCVector3 &X, const CCVector3 &Y, const CCVector3 &N) |
Sets the best interpolating plane equation (Least-square) More... | |
const CCVector3 * | getLSPlaneX () |
Returns best interpolating plane (Least-square) 'X' base vector. More... | |
const CCVector3 * | getLSPlaneY () |
Returns best interpolating plane (Least-square) 'Y' base vector. More... | |
const CCVector3 * | getLSPlaneNormal () |
Returns best interpolating plane (Least-square) normal vector. More... | |
const PointCoordinateType * | getQuadric (Tuple3ub *dims=nullptr) |
Returns the best interpolating 2.5D quadric. More... | |
bool | compute3DQuadric (double quadricEquation[10]) |
Computes the best interpolating quadric (Least-square) More... | |
SquareMatrixd | computeCovarianceMatrix () |
Computes the covariance matrix. | |
PointCoordinateType | computeLargestRadius () |
Returns the set 'radius' (i.e. the distance between the gravity center and the its farthest point) | |
Static Public Attributes | |
static constexpr int | IGNORE_MAX_EDGE_LENGTH = 0 |
static constexpr bool | DUPLICATE_VERTICES = true |
static constexpr bool | DO_NOT_DUPLICATE_VERTICES = false |
PointCoordinateType | m_quadricEquation [6] |
2.5D Quadric equation More... | |
Tuple3ub | m_quadricEquationDirections |
2.5D Quadric equation dimensions More... | |
PointCoordinateType | m_lsPlaneEquation [4] |
Least-square best fitting plane parameters. More... | |
CCVector3 | m_lsPlaneVectors [3] |
Least-square best fitting plane base vectors. More... | |
CCVector3 | m_gravityCenter |
Gravity center. More... | |
unsigned char | m_structuresValidity |
Geometrical elements validity (flags) | |
GenericIndexedCloudPersist * | m_associatedCloud |
Associated cloud. | |
Typically suited for "nearest neighbours". It implements the GenericIndexCloud interface by inheriting the ReferenceCloud class.
Most of them are defined in "Contour detection in unstructured 3D point clouds", Hackel et al, 2016 PCA1 and PCA2 are defined in "3D terrestrial lidar data classification of complex natural scenes using a multi-scale dimensionality criterion: Applications in geomorphology", Brodu and Lague, 2012
explicit |
associatedCloud | reference cloud |
bool Neighbourhood::compute3DQuadric | ( | double | quadricEquation[10] | ) |
[out] | quadricEquation | an array of 10 coefficients [a,b,c,d,e,f,g,l,m,n] such as a.x^2+b.y^2+c.z^2+2e.x.y+2f.y.z+2g.z.x+2l.x+2m.y+2n.z+d = 0 |
ScalarType Neighbourhood::computeCurvature | ( | const CCVector3 & | P, |
CurvatureType | cType | ||
double Neighbourhood::computeFeature | ( | GeomFeature | feature | ) |
ScalarType Neighbourhood::computeMomentOrder1 | ( | const CCVector3 & | P | ) |
ScalarType Neighbourhood::computeRoughness | ( | const CCVector3 & | P, |
const CCVector3 * | roughnessUpDir = nullptr |
P | point for which to compute the roughness value |
roughnessUpDir | up direction to compute a signed roughness value (optional) |
const CCVector3 * Neighbourhood::getGravityCenter | ( | ) |
const PointCoordinateType * Neighbourhood::getLSPlane | ( | ) |
Returns an array of the form [a,b,c,d] such as: ax + by + cz = d
const CCVector3 * Neighbourhood::getLSPlaneNormal | ( | ) |
This corresponds to the smallest eigen value (i.e. the second largest cloud dimension)
const CCVector3 * Neighbourhood::getLSPlaneX | ( | ) |
This corresponds to the largest eigen value (i.e. the largest cloud dimension)
const CCVector3 * Neighbourhood::getLSPlaneY | ( | ) |
This corresponds to the second largest eigen value (i.e. the second largest cloud dimension)
const PointCoordinateType * Neighbourhood::getQuadric | ( | Tuple3ub * | dims = nullptr | ) |
Returns an array of the form [a,b,c,d,e,f] such as: Z = a + b.X + c.Y + d.X^2 + e.X.Y + f.Y^2
inline |
Projected points are stored in the points2D vector.
points2D | output set |
planeEquation | custom plane equation (otherwise the default Neighbouhood's one is used) |
O | if set, the local plane base origin will be output here |
X | if set, the local plane base X vector will be output here |
Y | if set, the local plane base Y vector will be output here |
vectorsUsage | Defines how input vectors should be used |
void Neighbourhood::setGravityCenter | ( | const CCVector3 & | G | ) |
Handle with care!
G | gravity center |
void Neighbourhood::setLSPlane | ( | const PointCoordinateType | eq[4], |
const CCVector3 & | X, | ||
const CCVector3 & | Y, | ||
const CCVector3 & | N | ||
Handle with care!
eq | plane equation (ax + by + cz = d) |
X | local base X vector |
Y | local base Y vector |
N | normal vector |
GenericIndexedMesh * Neighbourhood::triangulateOnPlane | ( | bool | duplicateVertices, |
PointCoordinateType | maxEdgeLength, | ||
std::string & | outputErrorStr | ||
Cloud selection is first projected on the best least-square plane.
duplicateVertices | whether to duplicate vertices (a new point cloud is created) or to use the associated one) |
maxEdgeLength | max edge length for output triangles (IGNORE_MAX_EDGE_LENGTH = ignored) |
outputErrorStr | error (if any) |
protected |
Gravity center.
Only valid if 'structuresValidity & GRAVITY_CENTER != 0'.
protected |
Array [a,b,c,d] such that ax+by+cz = d Only valid if 'structuresValidity & LS_PLANE != 0'.
protected |
protected |
Array [a,b,c,d,e,f] such that Z = a + b.X + c.Y + d.X^2 + e.X.Y + f.Y^2.
protected |
Array (index(X),index(Y),index(Z)) where: 0=x, 1=y, 2=z Only valid if 'structuresValidity & QUADRIC != 0'.
